formating STM3500418AS https://vlab.su/viewtopic.php?f=49&t=14236 |
P.zonouz [ 04 июл 2013, 09:26 ] | |
Заголовок сообщения: | formating STM3500418AS |
I have seagate STM3500418AS. I can not format it, I did this before cleare smart update firmware to cc49 I try by this commands: ( after each command I restated hdd and test by victoria. in victoria test( write), after some blocke writed hdd cannot be detected ) F,,22 m0,6,2,,,,,22 m0,2,2,0,0,0,0,22 m0,8,2,1,1,,,22 ( this format it with 0000080491 error code). finally I could not format it. any advise? |
chulat [ 04 июл 2013, 10:03 ] | |
Заголовок сообщения: | Re: formating STM3500418AS |
use the Live-CD program then Low Level Format Tools |
RsM [ 04 июл 2013, 10:43 ] | |
Uncontrolled access to information - the evil. So you've been reading, and did not correct. As a result ruined the service area in the hard drive. So get yourself to blame ... |
P.zonouz [ 04 июл 2013, 18:40 ] | |
RsM писал(а): Uncontrolled access to information - the evil. So you've been reading, and did not correct. As a result ruined the service area in the hard drive. So get yourself to blame ... u think I ruined SA? but how? |
vmuse [ 12 июл 2013, 21:30 ] | |
I did not understand something from your post. Do you run these commands in com-port hyperterminal, or not? If no where, you printed it? |
