https://vlab.su/
Recomend me good software for copy files
https://vlab.su/viewtopic.php?f=49&t=15869
Страница 1 из 1
jackass25 [ 26 сен 2013, 20:05 ]
Заголовок сообщения:  Recomend me good software for copy files
right now im using teracopy.. since 1pm until now copy just 50%
i make 30gb of file copy to external hdd.8 hours for 30gb. yeah im using usb 2.0.. its normal?
winXP -core2 duo -4gb ram
misha2 [ 26 сен 2013, 21:00 ]
Заголовок сообщения:  Re: Recomend me good software for copy files
Show model of a hard disk and show its SMART.
jackass25 [ 28 сен 2013, 17:26 ]
WDC WD10 EARS-00MVWB0 SATA Disk Device (1000 GB, SATA-II)
and smart
ID Attribute Description Threshold Value Worst Data Status
01 Raw Read Error Rate 51 200 200 0 OK: Value is normal
03 Spinup Time 21 167 164 6616 OK: Value is normal
04 Start/Stop Count 0 100 100 339 OK: Always passes
05 Reallocated Sector Count 140 200 200 0 OK: Value is normal
07 Seek Error Rate 0 200 200 0 OK: Always passes
09 Power-On Time Count 0 100 100 446 OK: Always passes
0A Spinup Retry Count 0 100 100 0 OK: Always passes
0B Calibration Retry Count 0 100 100 0 OK: Always passes
0C Power Cycle Count 0 100 100 192 OK: Always passes
C0 Power-Off Retract Count 0 200 200 100 OK: Always passes
C1 Load/Unload Cycle Count 0 198 198 6998 OK: Always passes
C2 Temperature 0 119 107 31 OK: Always passes
C4 Reallocation Event Count 0 200 200 0 OK: Always passes
C5 Current Pending Sector Count 0 200 200 0 OK: Always passes
C6 Offline Uncorrectable Sector Count 0 200 200 0 OK: Always passes
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes
C8 Write Error Rate 0 200 200 0 OK: Always passes
Thanks.. :-):
misha2 [ 28 сен 2013, 21:25 ]
For example PC-3000 DiskAnalyzer, Ver1.02 or WinHex, DMDE.
laptopfix101 [ 25 окт 2013, 18:33 ]
PC-3000 is a very good one, thou expensive.
mrcomputer [ 04 ноя 2013, 19:20 ]
Try fast copy > http://ipmsg.org/tools/fastcopy.html.en
http://www.phpbb.com/
