Текущее время: 28 мар 2024, 19:33
Страница 1 из 1 [ Сообщений: 2 ] |
omex
Заголовок сообщения: REMOVE PASSWORD FROM YOUR LOCKED HDD WITH ZU HDD UNLOCKER Добавлено: 19 апр 2014, 05:02 |
Зарегистрирован: 27 авг 2013, 04:45 Наличности на руках: 60.03
Сообщения: 60 Откуда: Egypt
- go to bios and set Main--> IDE Configuration --> Onboard IDE Operate mode (set to Compatible Mode (need for MS-DOS), not set Enhanced Mode), go down 1 line and set Combined Mode Option to Primary P-ATA+S-ATA. - attach HDD to my ASUS P5GC-MX 1333 motherboard to sata2 port (in bios, it appear Fourth IDE Master)(there're 4 sata ports from sata1 to sata4 in my Motherboard, and you must attach to sata2 or sata4 port, see sata's port number on motherboard), disconnect all others hdd and CD-ROM. - set bios first boot from USB boot disk (in most case, must attach USB disk to computer first, and select proper USB boot device) - reboot into MS-DOS with USB boot disk, ignore the MHDD's instruction. - type at command prompt: c: - type zu.exe /s - and OLALA, just 2 seconds, can't bilieve in my eyes : DONE UNLOCK ! (or some thing like that, i don't remember exactly) - Congratulation, now your HDD Unlocked, and you can do anything to your HDD again. Don't forget to set your bios back to normal.
Use ZU /P, ZU /S or ZU /A you get within 1 second! INFO: DONE UNLOCK. If it does not work, dont worry!! Remember about settings bios: 1. Bios: AHCI -> IDE check ZU, nothing? 2. Check connect HDD to port: SATA0, SATA1, SATA2 etc. (I used 5) check ZU, nothing? 3. Bios: ata/ide: ENHANCED -> COMPATIBLE check ZU, nothing? 4. Check other mobo or computers. Good lock!
