seagate 1TB hdd https://vlab.su/viewtopic.php?f=49&t=81352 |
serwanjaf7 [ 09 окт 2018, 13:27 ] | |
Заголовок сообщения: | seagate 1TB hdd |
hello friend i have a seagate 1TB HDD it have problem i cant format and partition it when i connect it with the pc same time can detect the hdd but same time the hdd it jam ( not respond ) i need help if have any programe to fix it i tryed many software to fix it but i fail i think it have a bad sector thank you for help |
mia [ 09 окт 2018, 13:42 ] | |
Заголовок сообщения: | Re: seagate 1TB hdd |
Мotor is spinning ? Write full model name HDD. Internal or external? |
serwanjaf7 [ 09 окт 2018, 14:02 ] | |
thank you for replay the hdd is internal ( lenove laptop ) |
mia [ 09 окт 2018, 15:01 ] | |
Сonnect a HDD to a desktop computer and check on it |
serwanjaf7 [ 09 окт 2018, 15:12 ] | |
alredy i connected but it same |
mia [ 09 окт 2018, 15:21 ] | |
Software to check HDD http://www.dposoft.net/hdd.html https://hddguru.com/ |
serwanjaf7 [ 10 окт 2018, 14:45 ] | |
thank you |
