Текущее время: 01 ноя 2024, 04:17
 Заголовок сообщения: A1502 (820-3476-A) Can not read 25Q064A
СообщениеДобавлено: 18 авг 2016, 17:44
Hi,
I've a problem with reading the chip 25Q064A i use tl866cs and ezp2010 both off them doesn't recognize it some help will be appreciated
MacBook Pro A1502 820-3476-A 25Q064A
 Заголовок сообщения: Re: A1502 (820-3476-A) Can not read 25Q064A
СообщениеДобавлено: 18 авг 2016, 18:14
try 25L6406E or ST Brand or Micron brand
above 1 of 3 will work hopefully
and your ic brand is Numonyx also search for it your programmer.
do good have good
СообщениеДобавлено: 18 авг 2016, 18:45
unfortunately without success
СообщениеДобавлено: 19 авг 2016, 18:39
then problem is mainly with your ic
change your ic.bios file is availible on this site
is this simple?
do good have good
СообщениеДобавлено: 20 авг 2016, 13:08
I tried a few dumps system starts very slow. But yesterday i solved the problem i shorten the cables to 1 inch after then i was able to read and write
СообщениеДобавлено: 13 окт 2016, 11:48
Problem is in 1,8Vcc at "Q" series chips.
I modified my 5VDC SOIC8 ZIF adapter.
1. I cutted VCC line from ZIF to DIP.
2. Added in line two diodes in sequence, it make voltage drop approximative 1.4V 5-1,4 = 3,6v
3. Added a jumper between ZIF Vcc and DIP Vcc pins. It restores 5Vcc in other cases.
4. And then I added another line of two diodes in cutted Vcc line and added one more jumper.
3,6V-1,4V=2,2V This is enough to operate with "Q" series SPI FLASH ROMs.
In total I made power bus in this mode:
[2,2VDC] ZIF-Vcc-|<|-|<|-.[3.6VDC].-|<|-|<|-DIP-Vcc [5VDC]
And all works excellent!
В этой теме нет новых непрочитанных сообщений. a1502 (820-3476-a) Умерла 25q064a bios
в форуме Apple
volkol
05 июн 2023, 20:20
volkol Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook air a1466 820-3437А ( a1466 820-3437А) MacBook air a1466 25q064a 820-3437А или (В) bios dump help
в форуме Apple
djkomix
12702
03 май 2016, 16:52
djkomix Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Apple MacBook Pro A1502 (A1502 820-3476-A) нет старта
в форуме Apple
kuxar
23 янв 2020, 20:19
В этой теме нет новых непрочитанных сообщений. A1502 (820-3476 820-3536) нет картинки
в форуме Apple
igor.kts32
1634
14 июн 2021, 20:06
igor.kts32 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Драйвер подсветки LP8548B1SQ стоит на платах 820-3662 820-3787 820-3476 820-3536 820-4924
в форуме Куплю | Buy
kzverev
30 окт 2019, 22:32
kzverev Перейти к последнему сообщению
