Заголовок сообщения: A1466 Early 2015 EFI (OS X) efi pinout
Добавлено: 29 ноя 2016, 00:49
Зарегистрирован: 25 ноя 2013, 04:58 Наличности на руках: 20.04 Сообщения: 55 Откуда: serbia
Hello can someone provide efi pinout on logic board to flash the bios chip?
i try like this but can`t read the chip
MacBook Air "Core i5" 1.6 13" (Early 2015) 1.6 GHz Core i5 (I5-5250U) Intro. March 9, 2015* Order MJVE2LL/A* Model A1466 (EMC 2925) Family: Early 2015 ID : MacBookAir7,2
Зарегистрирован: 23 фев 2011, 12:57 Наличности на руках: 2,195.34 Сообщения: 2200 Откуда: Chisinau, Moldova
Chip pinout is same with standard DIP8/SOP8/SO8 SPI chips. Connector pinout is in attached picture.
But the best way is to desolder the chip, solder to programmer adapter DIP8, or use a "crocodile"-type adapter, reprogram chip using the SPI programmer, and then solder it back to MoBo. If You can't do this - better will be to try it in any serious IT service center.
It's not a some kind of test points, it's an in-system SPI programmer with special UEFI dump. Time for repairing UEFI PWD lock is same with total 64Mb SPI reprogramming time with new, good SPI programmer, based on CYPRESS MCU. I do this job not in 15 secs, but in 10 minutes. I use very old SPI programmer WILLEM2000 LPT. It works nice, and I don't want to change them.
unsolder you the chip or are you using this isp connector with your programmer?
I think to buy isp connector but for a reasonable price (if someone knows place to buy please share) this time i will try to find alternate points to solder on board or reomve chip with hotair. Posted after 1 hour 6 minutes 49 seconds: final pinout from boarview
Сейчас этот форум просматривают: brokonyer55 и гости: 9
