A1534 ( 820-00045-11) Bios dump https://vlab.su/viewtopic.php?f=51&t=110488 |
bokin021 [ 25 дек 2020, 11:53 ] | |
Заголовок сообщения: | A1534 ( 820-00045-11) Bios dump |
Hi everyone I need dump ..I found one on some site and when i flash it all voltage as good but not turn on..Also one more thing can i turn without battery only on charger? |
Shooter75 [ 25 дек 2020, 12:25 ] | |
Заголовок сообщения: | Re: A1534 ( 820-00045-11) Bios dump |
1. put back original ME region. 2. Yes, You can... 87W PSU + 85W powercable (with tweezers short GND and SYSdetect on battery conn). |
vzrivpaket [ 25 дек 2020, 12:48 ] | |
bokin021 писал(а): Hi everyone I need dump MacBook A1534. EMC ??? ---------- Добавлено спустя 38 минут 51 секунду: ---------- bokin021 viewtopic.php?f=51&t=6547&p=829946#p829946 |
bokin021 [ 25 дек 2020, 14:06 ] | |
it is back up |
vzrivpaket [ 25 дек 2020, 14:22 ] | |
bokin021 писал(а): it is back up Is this a backup ??? The file is corrupted... |
bokin021 [ 25 дек 2020, 15:52 ] | |
yes i know..Some one before me did it.,. Posted after 4 hours 42 minutes 13 seconds: I cant flash bios i use ch341a and wire connection i found on boardview conection ..Writen uknow chip..Maybe epprom die?I have 3.3v when i plug charger..Last time was ok.. |
