Заголовок сообщения: Component alternative for late 2008 A1278 M97
Добавлено: 22 мар 2013, 03:16
Зарегистрирован: 13 мар 2013, 18:06 Наличности на руках: 34.00 Сообщения: 8 Откуда: Eindhoven, the Netherlands
Hey guys,
I'm fixing a 1278 late 2008 MacBook (unibody but not pro, M97 board). After a lot of searching (amateur ;)) I've found there's a component missing: a Schottky Barrier Diode (SBD) with reference D7010 and part number 1SS418 (see attachment).
I probably won't be able to find exactly the same part. Is a 30v SBD in a SMT package enough, or should I pay attention to other details? Do you guys know what I should order to get a good replacement part?
Kind regards,
Rick
zsibvasaros69
Заголовок сообщения: Re: Component alternative for late 2008 A1278 M97
Добавлено: 22 мар 2013, 13:03
Зарегистрирован: 20 мар 2013, 11:51 Наличности на руках: 14.00 Сообщения: 23
Добавлено: 22 мар 2013, 15:06
Not at all! I hope This diode is a good choice. :)
rvanpruissen
Добавлено: 10 апр 2013, 00:33
After a bit of delay, the part has been ordered (difficult to find without being a company!). Do you guys this tiny component is causing all my issues (no response, but has G3HOT), or should I look further before replacing?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
