Заголовок сообщения: a1342 doesn't wake up from sleep
Добавлено: 22 мар 2013, 18:00
Зарегистрирован: 20 мар 2013, 11:51 Наличности на руках: 14.00 Сообщения: 23
Hello Everybody,
I have an a1342 macbook unibody white. It's work fine, but it doesn't wake up from the sleep mode. It can go to sleep mode (the hall sensor detects when the lid is closed), but it doesn't wake up. I replaced the hall sensor board on the logic board and I checked the lid sensor line, but everything is ok. I tried the SMC and PVRAM reset, but these aren't usefull. The number of logic board is 820-2883-A. Anyone has idea?
Thank you!
Bence
zsibvasaros69
Заголовок сообщения: Re: a1342 doesn't wake up from sleep
Добавлено: 23 мар 2013, 15:19
Could anybody help me to solve this problem?
Thank you!
alexasha8311
Добавлено: 23 мар 2013, 17:09
It is controled by SMC. Do you think it workes faulty?
zsibvasaros69
Добавлено: 24 мар 2013, 15:02
I replaced the SMC yesterday, but the mac isn't repaired by the replace. Is this a software problem?(for eg. EFI...)
zsibvasaros69
Заголовок сообщения: Re: a1342 doesn't wake up from sleep [РЕШЕНО]
Добавлено: 25 мар 2013, 22:44
I found the faulty of the logic board. This is an amplifier IC, which drives the loud speaker. It was short-circuited and it didn't allow to wake up the macbook. I replaced it today since then it has worked fine.
Сейчас этот форум просматривают: iService и гости: 11
