Заголовок сообщения: Macbook Pro 17'' (820-2914-B) No display after reattaching GPU
Добавлено: 05 апр 2014, 23:09
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 30.00 Сообщения: 198 Откуда: Ghana
Hi everyone, 216-0810084 AMD chipset was bought from ic-chipset.com already reballed. After reattaching the gpu, the mac powers up with chiming sound and the fan spins continuously but no display. I have checked surrounding components and everything looks intact.All voltages on the board are correct with the exception of PPVCORE_S0_AXG rail which is 0.486v instead of 1.05v according to schematic, I don't know if that has got anything to do with my issue. The gpu has seated correctly because I marked the corners before taking out the old one which got shorted during re-flow. I have checked the chip with a magnifying glass and it is evenly seated on the motherboard. Any advice will be much appreciated.
orbit
Заголовок сообщения: Re: Macbook Pro 17'' (820-2914-B) No display after reattaching GPU
Добавлено: 06 апр 2014, 00:12
Зарегистрирован: 20 апр 2012, 10:57 Наличности на руках: 1,480.94 Сообщения: 1632 Откуда: Россия г. Санкт-Петербург
Вам нужен реально новый 216-0810001. Не реально найти новый 216-0810084, а мертвый чип работать не будет и не важно reballed он или refurbished. Деньги на ветер.
_________________ Ремонт ноутбуков Санкт-Петербург +79313406112 Ессентуки+79283151170
