Текущее время: 29 мар 2024, 04:53
 Заголовок сообщения: APPLE A1200 (APPLE iMAC 24" ) API5ST06-290G power supply issue.
СообщениеДобавлено: 30 янв 2016, 22:52
Hi.
This power supply is function only for 5 seconds, and then stops working.
There are good pulses in pin 9 of NCP1381, but this pulses decreases its amplitude when they reach the gate of output power switch mosfet. (also pulses are distorted)
This pulses goes trough a 470 ohms resistor (R64) and a ¿transistor? (Q5) from pin 9 to mosfet's gate.
Probably Q5 is a bipolar PNP transistor, but is impossible to know. (there is no schematic, and transistor seems damaged)
All electrolytic capacitors has been changed, and also R83. (475 ohms)
Can anybody help me to locate a equivalent transistor? (the body of the transistor are marked as 350A)
Thanks.
PS: Q5 seems very very likely as Q1 in the schematic below.
 Заголовок сообщения: Re: APPLE A1200 (APPLE iMAC 24" ) API5ST06-290G power supply issue.
СообщениеДобавлено: 16 фев 2016, 20:31
This power supply is function properly now.
Q5 is as I thought a PNP bipolar transistor. The problem, without schematic, is to get one with similar characteristics to replace it, then I saw a similar transistor (Q1) in the same power supply but in a different circuit: the PFC circuit.
Fortunately I have another identical power supply, but without Q5, (have a few components on it) but Q1 transistor in PFC circuit was there, so I take it and put it in Q5's place.
Now the drive pulses for the power mosfet are good and the psu works like a charm.
Probably a good equivalent would be a 2STR2230 transistor. ( BJT, PNP, -30V, -1.5A, SOT23)
I hope this information could help someone else.
Regards.
В этой теме нет новых непрочитанных сообщений. Apple iMac A1200 (A1200) нужна схема БП
в форуме Apple
Михаил2115
11 мар 2016, 17:17
Михаил2115 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung keyboard maping issue NP450R5E (ramos) keyboard maping issue
в форуме Samsung
minanpil13
03 апр 2019, 10:30
minanpil13 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. iMAC A1200 (APPLE) Проблема с видео
в форуме Apple
slashok
05 дек 2015, 15:52
slashok Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3421 no power (12204-1 DNE40-CR MB PWB 5J8Y4 REV AOO) i Have problem with dell 3421 no power issue. Its 5
в форуме Dell
alexasha8311
23 фев 2016, 09:34
and555 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Apple Magsafe 1 Power Supply 18.5Volt 4.6Amp AP85W1210
Andrush
1758
07 дек 2018, 12:07
Witewut Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
