Apple Macbook Air 13 Motherboard For A1466 ( 820-00165-a) bios needed https://vlab.su/viewtopic.php?f=51&t=57671 |
salim.thebadboy [ 23 фев 2017, 17:11 ] | |
Заголовок сообщения: | Apple Macbook Air 13 Motherboard For A1466 ( 820-00165-a) bios needed |
hello guys can any body remove the password from the backup coz i flashed other dump but its very slow best regards and thanks |
Shooter75 [ 23 фев 2017, 21:07 ] | |
Заголовок сообщения: | Re: Apple Macbook Air 13 Motherboard For A1466 ( 820-00165-a) bios needed |
О! Мигранты в Европе освоились и настроили каналы свиста ноутов... Салим.Плохиш из Бельгии, прям слезы на глазах... Freezing not depends of password lock. Renewing of ME region - resolves Your problem. About Your UEFI img. Your notebook is stolen. It's iCloud locked. But about unlocking,here is Your solution. And the policeman is on the way to You. |
kocx520 [ 25 фев 2017, 22:44 ] | |
Заголовок сообщения: | Re: Apple Macbook Air 13 Motherboard For A1466 ( 820-00165-a) bios needed [РЕШЕНО] |
Hello friend, try this file MacBook Air A1466 820-00165-A A1466 820-00165-A Clean ME Clean Password Important: **You have to change the SN Find XXXXXXXXXXXX in your hex editor** **And replaces by your SN** After programming you have to do a NVRAM reset And comment if it works |
