macbook air (A1406) BIOS NEED https://vlab.su/viewtopic.php?f=51&t=70737 |
basic [ 14 янв 2018, 14:55 ] | |
Заголовок сообщения: | macbook air (A1406) BIOS NEED |
MacBook Air Model A1406 NEED BIOS 020-7377a |
Bucha [ 14 янв 2018, 15:11 ] | |
Заголовок сообщения: | Re: macbook air (A1406) BIOS NEED |
Оn the model of the board you need to search, for example 820-***** Тhen look here |
basic [ 14 янв 2018, 15:14 ] | |
i will try to find but i cant ... Posted after 7 minutes 42 seconds: 020-7377a |
Shooter75 [ 14 янв 2018, 19:29 ] | |
basic писал(а): 020-7377a it's a battery pac p/n. Try at MLB. It must be 820-3024-A. f/e. |
basic [ 14 янв 2018, 20:13 ] | |
yes i found it it is : 820-3024-B Posted after 28 minutes 36 seconds: do u know what kind of programer do use , my programer cant flash 25Q064 ... |
gofer [ 14 янв 2018, 23:16 ] | |
Check this dump: viewtopic.php?f=51&t=6547&p=517317&hilit=%2A3024+bios%2A#p517317 |
basic [ 15 янв 2018, 17:45 ] | ||||
Заголовок сообщения: | Re: macbook air (A1406) BIOS NEED | |||
i found the bios and now everything is ok thnx guys
