a1286 (820 2850 A ) Question about SMC https://vlab.su/viewtopic.php?f=51&t=71358 |
SpinNNN [ 29 янв 2018, 21:00 ] | |
Заголовок сообщения: | a1286 (820 2850 A ) Question about SMC [РЕШЕНО] |
Hey Guys, i have a board "820 2850-A" with a smc problem but Only have a "820 2915-B" to replace the SMC.. Can i replace a SMC from "820 2915-A" in a "820 2850-A" ??? someone try to replace that ?? Thank you |
Shooter75 [ 30 янв 2018, 00:32 ] | |
Заголовок сообщения: | Re: a1286 (820 2850 A ) Question about SMC |
Try to compare i/o ports of temperature sensors by schematics diagrams. If differences will be found - it impossible to change with that one. Only with absolute coincidence MCUs can be used as donors. Tables of I/O ports of sensors are programmed at memory regions in MCU, and can not be reprogrammed by usual methods. In this case You can use this MCU only for diagnostics use. |
SpinNNN [ 30 янв 2018, 03:01 ] | |
Already understood. I will buy a same donor board to remove the SMC. Thank you one more time |
