Текущее время: 26 апр 2024, 18:34
 Заголовок сообщения: MacBook Pro A1502 (820-4924-A) Backlight Sensor Issues
СообщениеДобавлено: 20 авг 2018, 23:40
Hi everyone, I have this peculiar back-light issue.The MacBook came to me with a broken L7710, and after replacing, it powers on without back-light, but when I close and open the Lid or when I pass a magnet around the HALL Sensor area, the back-light appears.I have also noticed that when I pass the magnet around the Sensor whilst the screen is on, it does not go off even though it's supposed to. I have reset PRAM but that has not helped and there is no sign of liquid damage anywhere.I want to know if someone has come across this issue before and whether its a hardware or firmware issue.Thanks in advance.
 Заголовок сообщения: Re: MacBook Pro A1502 (820-4924-A) Backlight Sensor Issues
СообщениеДобавлено: 22 авг 2018, 14:07
L7710 delivered with the same value? This is critical.
Check the entire lighting circuit from the circuit. It may be necessary to replace the U7700. I think the problem is hardware.
Поиск знаний неортодоксальными методами.
СообщениеДобавлено: 14 сен 2018, 12:29
The macbook was taken away but another board came with the same issue and these are the voltages on screen connector (J8300) when powered on with image on screen and no backlight;
PPVOUT_S0_LCDBKLT -51.8v
I2C_BKLT_SCL - 5.36v (oscilloscope activity)
I2C_BKLT_SDA - 5.36v (oscilloscope activity)
PP3V3_S0_EDR - 3.3v
SMBUS_SMC_0_S0_SCL - 3.3v (no oscilloscope activity)
SMBUS_SMC_0_S0_SDA - 3.3v (no oscilloscope activity)
EDP_BKLT_PWM - 3.6v (oscillocope activity)
LCD_HPD_CONN - 2.48v
LCD_IRQ_L - 3.28v
PP5VR3V3_SW_LCD - 5.28v
SMC_LID is also 3.3v with backlight off
When I close the screen or bring a magnet near the Hall Sensor,the backlight comes on.Anytime the backlight goes off, the screen has to be closed and opened before the backlight comes on.Could this be an SMC issue?. I will be grateful if someone can point out which other signals control backlight switching apart from the hall sensor.
СообщениеДобавлено: 16 сен 2018, 14:46
Make sure the screen is compatible with the model.
https://webcache.googleusercontent.com/ ... backlight+
(using a webcache link since their site is not working properly right now)
 Заголовок сообщения: Re: MacBook Pro A1502 (820-4924-A) Backlight Sensor Issues  [РЕШЕНО]
СообщениеДобавлено: 20 сен 2018, 03:02
Thanks so much for the info. I somehow suspected it because there was a tamper proof sticker at the bottom of the screen, which suggested that the screen might have been replaced (and obviously with the wrong one). Unfortunately i never got a similar laptop to check the motherboard with and the customer has come for it.Thanks once again.. :-ok-:
В этой теме нет новых непрочитанных сообщений. MACBOOK PRO (A1502) 820-4924-A BIOS FILE
в форуме Apple
linyex
21 окт 2015, 01:21
houcine4500 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1502 (820-4924-A) Нет подсветки в начале загрузки
в форуме Apple
max_f
21 мар 2017, 22:50
max_f Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1502 (820-4924-A) Нет подсветки дисплея
в форуме Apple
guljaysv
17 авг 2017, 11:24
guljaysv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1502 (820-4924-A) помогите опознать элемент
в форуме Apple
igorosa1
23 сен 2017, 10:46
В этой теме нет новых непрочитанных сообщений. Macbook Pro(A1502) (820-4924-a) Не включается
в форуме Apple
vverbovenko91
11 окт 2017, 18:05
vverbovenko91 Перейти к последнему сообщению
Сейчас этот форум просматривают: kavon, zaryasto и гости: 17
