Текущее время: 04 июн 2024, 17:56
 Заголовок сообщения: HP Elitebook 8470p bios password remove (HP Elitebook 8470p bios password remove) HP Elitebook 8470p bios pass
СообщениеДобавлено: 24 окт 2014, 00:30
Can somebody remove the bios password of this original dump?
i found a clean dump but i get machine not in commited state.
somebody help me?
 Заголовок сообщения: Re: HP Elitebook 8470p bios password remove (HP Elitebook 8470p bios password remove) HP Elitebook 8470p bios
СообщениеДобавлено: 24 окт 2014, 09:37
somebody help me?
http://www.mediafire.com/download/d4kac ... backup.bin
СообщениеДобавлено: 24 окт 2014, 11:37
Bios Configuration Utility http://notebook1.ru/forma1/viewtopic.php?f=387&t=96778
Цитата:
...всё достаточно прозрачно написано в BIOS Configuration Utility User Guide
run CMD: BiosConfigUtility64.exe/getconfig:config.txt
Edit config.txt
Цитата:
Manufacturing Programming Mode
*Unlock
Lock
Unlock
*Lock
BiosConfigUtility64.exe/setconfig:config.txt
or use AMTOOLS
or wndmifit from HPDmitool viewtopic.php?f=53&t=4421
СообщениеДобавлено: 26 окт 2014, 04:35
Thank's Sergej
But can you tell me how this tool work for example how can i delete the bios password?
must i create a text file and write something?
thank's again
СообщениеДобавлено: 02 ноя 2014, 18:22
You have 2-3 ways to reset bios password on recent HP (Elite- and Probook).
1- Try MAZZIF patch to creat key and reset password, reseting TPM.
2- If device also have MPM then MAZZIF's patch wont help you. The easiest way then is to program the bios-chip in a programmer ( such are sold on eBay ) for about 7$.
If you plan to flash bios with a programmer then you have to take a pic for the bios information page with all the numbering for various titles. Keep the pic for later use because programming will wipe the UUID, serial number.....etc. Those needed to be tattoo-ed to device using the DMI tool.
3- create new adminstartator account within windows, HP security manager that will allow you to enter all bios options except for the password but you can at least change boot-device ...etc. There are blogs decribing how to do it.
I can provide you links for the Mazzif blog, eBay supplier ...etc. I don't know though how accepted it is by forum roles to link to other sites???. New in forum. '
Best regards.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. elitebook bios password remove (elitebook bios password remove) elitebook bios password remove
zenelli
14 июл 2014, 08:35
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Latitude 3340 (Password) how to remove password
в форуме Dell
nafienew
17 мар 2015, 08:04
evserv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Fujitsu Lifebook AH530 (DA0FH2MB6E0) Hot to remove bios password
в форуме Fujitsu-Siemens
mun4o
10 фев 2015, 02:27
mun4o Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo thinkpad (t440) remove password bios supervisor
sifocool
6373
02 ноя 2016, 01:20
unis Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP (820 g1) BIOS PASSWORD REMOVE
basic
19 апр 2018, 20:08
basic Перейти к последнему сообщению
Сейчас этот форум просматривают: dtvog, gorbunov2013, KotLove, krugliy, set-762 и гости: 32
