Текущее время: 23 май 2024, 10:33
 Заголовок сообщения: HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)
СообщениеДобавлено: 27 фев 2015, 15:13
helloo
i have a HP Elitebook 8560P with NO sound comming from the peackers or from headphones.
I ALLREADY checked:
*several drivers and windows versions (everything looks normal in device manager)
*BIOS update
*different speackers
* checked the jacks
* changed the IDT 92HD080B1X5
AND still the same problem, the device is installed i can turn volume up and down..but no audio!
ANY OTHER IDEEA?
 Заголовок сообщения: Re: HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)
СообщениеДобавлено: 03 мар 2015, 23:10
brogdan писал(а):
ANY OTHER IDEEA?
You can check wires. Recently I had some trouble with wires from motherboard to "headphones OUT/ mic IN" plate on the EliteBook 8470p. When I installed the bottom case I squeezed this wires and got some mysterious problem with sound.
СообщениеДобавлено: 04 мар 2015, 16:40
I just checked 8460p - it has no wires on the "speaker in/out" board.
This board attached by socket directly to the motherboard.
Although you can check Device manager - may be speaker has a checked "disabled" option.
СообщениеДобавлено: 04 мар 2015, 17:02
yes it has a small pcb board with a connector, it's not a software problem. i allready checked device manager an drivers.
in device manager everything looks ok, even when i click the volume icon i can move the volume up and down, i see the green bar but no sound.
Posted after 1 hour 45 minutes 59 seconds:
dose anyone have a datasheet for this model? maybe i can figure it out
СообщениеДобавлено: 09 мар 2015, 02:48
Which kind of datasheet do you want?
Simple use warranty for this pcb and forget of it.
СообщениеДобавлено: 09 мар 2015, 13:58
i don't have warranty for this laptop.
СообщениеДобавлено: 09 мар 2015, 19:04
Are you sure?
You can type me in PM your serial no and I can check it warranty status.
Need to know - 90% of the EliteBook has a 3 year WORLDWIDE warranty.
It note that series 8x60 starts in 2011 most of them still on active warranty.
On last week I done 2 warranty repair of 8560p.
СообщениеДобавлено: 17 май 2015, 20:52
Hi, had the same problem, by me was no power on pin 27 of IDT chip, found U5 (2,5V LDO) defective, after changing it sound come again.
 Заголовок сообщения: Re: HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)  [РЕШЕНО]
СообщениеДобавлено: 16 июл 2015, 14:53
thank you mihaicozac! that was my problem too. Changed U5 and now sound is back to normal
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. probook 6560b (cure dis hr hpb) не вкл
сергей петрович
3402
13 янв 2020, 15:56
Mishabr Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Elitebook 8560P (CURE-UMA_HR_HPB) it shut down after 30 mins
ayad
22 июн 2017, 21:03
Raimondas Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteBook 8560p (CURE-DIS_HR_HPB MV_MB_V1) проблемы с ME регионом
sevastd
16
2219
05 мар 2021, 18:39
sevastd Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. 8560p (Cure-uma) Проблема с биосом и ме
Raimondas
3891
15 июл 2017, 12:53
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Hp 8560P (CURE-DIS_HR_HPB) черний екран на матрице
Andrush
30 авг 2018, 20:21
Andrush Перейти к последнему сообщению
Сейчас этот форум просматривают: FlashService, hachikkz, Oleg Gutorov и гости: 27
