Текущее время: 23 май 2024, 08:59
scobay
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 13 сен 2017, 17:36 |
Сообщения: 106 Откуда: Ireland
gserg писал(а): kbc_rst 0v, а должен быть высоким. Его должен поднять HUB , или он мертв или что то не так. kbc_rst 0v, and should be high. It should raise a HUB, or he's dead or something's wrong. Hi yes but as there was a definite bios issue I didnt suspect the FCH to be faulty also , what conditions need to be present for FCh to output kbc_rst ?
scobay
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 13 сен 2017, 22:01 |
seminenko писал(а): SUSB# , SUSС# ? Both are 3.3v after button press
gserg
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 14 сен 2017, 12:15 |
Зарегистрирован: 11 фев 2015, 13:06 Наличности на руках: 68.45
Сообщения: 770 Откуда: рф
scobay писал(а): what conditions need to be present for FCh to output kbc_rst ? before that, the bridge must poll all the peripherals, LAN codec , Audio codec, cadrider, ets... and get on the bus response "ready", if one of them does not respond, reset will not rise. I do not understand -draws .2a, is a monitor postkarte ? or...
_________________ Пиши по делу, ибо внемлющие слововоблудию впадают в рукоблудие
scobay
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 14 сен 2017, 13:23 |
gserg писал(а): scobay писал(а): what conditions need to be present for FCh to output kbc_rst ? before that, the bridge must poll all the peripherals, LAN codec , Audio codec, cadrider, ets... and get on the bus response "ready", if one of them does not respond, reset will not rise. I do not understand -draws .2a, is a monitor postkarte ? or... Draws .2a (200mah) as im using a bench supply so I can see how much current is being drawn. Is there a block diagram of this Apu available that will list the order the signal should be present in? Posted after 35 minutes 27 seconds:scobay писал(а): gserg писал(а): scobay писал(а): what conditions need to be present for FCh to output kbc_rst ? before that, the bridge must poll all the peripherals, LAN codec , Audio codec, cadrider, ets... and get on the bus response "ready", if one of them does not respond, reset will not rise. I do not understand -draws .2a, is a monitor postkarte ? or... Draws .2a (200mah) as im using a bench supply so I can see how much current is being drawn. Is there a block diagram of this Apu available that will list the order the signal should be present in? Apu is am50000ibj44hm. no FCH in this model.
gserg
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 14 сен 2017, 18:31 |
scobay писал(а): no FCH in this model. I'm sorry ,especially for you http://www.cpu-world.com/CPUs/Jaguar/AM ... -5000.htmlIntegrated peripherals / components Integrated graphics GPU Type: Radeon HD 8330 Microarchitecture: Sea Islands Shader cores: 128 Base frequency (MHz): 497 Memory controller The number of controllers: 1 Memory channels: 1 Channel width (bits): 64 Supported memory: DDR3-1600, DDR3L-1600 DIMMs per channel: up to 2 Maximum memory bandwidth (GB/s): 12.8 Other peripherals PCI Express 2.0 interface (4 lanes)Universal Video Decoder 4.2 Video Compression Engine 2.0 ? High Definition Audio SD controller USB 3.0 controller Serial ATA 3.0 controller LPC bus General Purpose I/O ---------- Добавлено спустя 3 минуты 12 секунд: ---------- gserg писал(а): Apu is am50000ibj44hm. no FCH in this model. I'll tell you more, this APU does not exist
gserg
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 15 сен 2017, 12:51 |
scobay писал(а): Im not sure what you mean? на твоем фото am5000 а не am50000 on your photo am5000 not am50000
scobay
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 15 сен 2017, 21:29 |
gserg писал(а): scobay писал(а): Im not sure what you mean? на твоем фото am5000 а не am50000 on your photo am5000 not am50000 Apologies I put 1 0 too many.
gserg
Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn Добавлено: 16 сен 2017, 12:09 |
back to the problem in the PCH chip is, it is a fact, the Condition for removing signal reset following 1. all power must be present. 2. The presence of RTC Clock and the SYSTEM Clock (check with oscilloscope with high impedance probe 1:10, or the touch of the probe to quench the generation and you'll see nothing) 3. System bus request is sent and response is returned on the readiness of peripheral devices. If the bus is in doun (someone from the periphery dead, and does not give it up) will not be reset in the high state. From all written to be what you need postkarte and consistent removal of network codec, card reader , audio, USB3 and polec each operation to check the status of the reset and the presence postcodes. While all, good luck. Сообщение не в тему Pardon for my English, in school I was tortured by the French, but I can't remember
