77romantik77 писал(а):
biosconfigutility64.exe /set:config.ini - соответственно сохраняет
Здравствуйте.
Сделала всё по инструкции но он дает ошибку по некоторым параметрам(((( (вместо серийников поставила прочерки--------)
Не сталкивались с таким?
C:\BCU>biosconfigutility64.exe /set:config.ini
<BIOSCONFIG Version="" Computername="DESKTOP-J3NRH5D" Date="2021/02/26" Time="07:12:28" UTC="3">
<SETTING changeStatus="fail" name="SKU Number" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П]]></OLDVALUE>
<NEWVALUE><![CDATA[----------------]]></NEWVALUE>
</SETTING>
<SETTING changeStatus="fail" name="Serial Number" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П]]></OLDVALUE>
<NEWVALUE><![CDATA[--------------]]></NEWVALUE>
</SETTING>
<SETTING changeStatus="fail" name="Product Name" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П]]></OLDVALUE>
<NEWVALUE><![CDATA[HP Notebook 17-y042ur]]></NEWVALUE>
</SETTING>
<SETTING changeStatus="fail" name="Mac Address" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[FFFFFFFFFFFF]]></OLDVALUE>
<NEWVALUE><![CDATA[---------------]]></NEWVALUE>
</SETTING>
<SETTING changeStatus="fail" name="System Board CT Number" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П╤П]]></OLDVALUE>
<NEWVALUE><![CDATA[-------------------]]></NEWVALUE>
</SETTING>
<SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[Lock]]></OLDVALUE>
<NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
</SETTING>
<ERROR msg="An operation failed" />
<ERROR msg="BCU return value" real="13" translated="13" />
</BIOSCONFIG>
А при использование NBDMITOOL :
А где брать этот параметр UUID ?
