Текущее время: 05 май 2024, 19:51
Страница 1 из 1 [ 1 сообщение ] |
amennone
Заголовок сообщения: HP Pavillon27 All-In-One (completely off) DA0N73MB6D0 REV:D Добавлено: 15 авг 2021, 23:59 |
Зарегистрирован: 06 фев 2018, 22:46 Наличности на руках: 11.00
Сообщения: 6 Откуда: salerno italy
HP Pavillon27 All-In-One Model No. 27-r006nl Product No. 2XC73EA#ABZ Main board DA0N73MB6D0 REV:D No light blinks, the fan is not spinning, on the SPI 25Q64F, no voltage.
Voltage presence LED on.
Power supply O.K.
I disconnected the battery from the bios in an attempt to reset, nothing has changed.
Looking for diagram Main board DA0N73MB6D0 REV: D.
I have a short on pin 8 of the SPI 25Q64F, towards ground I read 0 ohm. I also removed G9661, Peak 3A, Low Dropout Regulator with Enable, but the short persists. Checked and removed capacitors affected by the short, without success. Without a scheme I see it difficult, I trust in your help. Thanks for the moment .
