Текущее время: 08 май 2024, 04:21
 Заголовок сообщения: HP 15-fh0013dx (LA-M798P) LDO does not rise
СообщениеДобавлено: 01 апр 2024, 20:33
Hello everyone, I need help in trying to make sense of where the fault could be.
1. TPS65994 has no separate bios chip, which suggest the firmware could be in the main bios chip.
- It draws only 5v/.027A. there are no shorts to the capacitors around it and caps read way above 1000 in doide mode.
- there are 1.5v, 3.4v, and 13.5v on 3 caps around the chip.
2. ISL9538BH has 5.1v and 4.8v on pin 16(ADP) and 17(DCIN) respectively.
- pin 19(ACIN) has 0.938v.
- pin 24(ACOK) has 3.2v.
- both 21(SDA)/22(SCL) have .092v. there is no short on both pins.
- pins 1(CSON) 2(CSOP) 3(VSYS) all have 16.77v
3.SY8388BRHC has no shorts anywhere.
- 16.77v on pins 2,3,4.
- pin 8(ENLDO) has 0.241v
- diode mode reading on pin 8 is in excess of 2000
- voltage divider circuitry resistor values of 499K and 150k to pin 8 (ENLDO_3V5V) are accurate.
- pin 13(LDO) which should output +3VLP is only .047v and there is no short on that voltage rail.
- as a result there is no +3VALWP, which also has no short on that rail.
4.SY8370CTMC also has no shorts anywhere.
- pin 1(IN) is 16.77v
- pin 5(ENLDO) shares the same voltage divider with SY8388BRHC and also has 0.241v
- diode mode reading of pin 5 in excess of 2000.
- no +5VLP on pin 9 and no short.
- no +5VALWP on pin 12 and no short.
The obvious issue here is +3VLP, which must be available to initiate everything. so I decided to experiment and replaced SY8388BRHC with SY8386B, which has same pin values and the readings were same as above which suggests that SY8388BHRC seems ok. so I went a step further and applied 3v from Lab power to pin 8(ENLDO) and lo and behold, +3VLP, +3VALWP, +5VLP, +5VALWP all shot up as well as the power led indicator and USBC voltage also shot up to 20V and battery is charging.
My issue here is why the value of the resistors are the same yet LDO is not enabled. I desoldered the resistors and checked and even replaced them. I have to mention that the schematics for LA-M798P is unavailable so I had to fall on LA-G341P,0P5A,LA-K971P and LA-K061P. checks with voltage divider apps online suggests that the voltage should be approximately 3.9v but I'm reading 0.241v on the motherboard, and there is no short on that line.
Any suggestions will be greatly appreciated.
 Заголовок сообщения: Re: HP 15-fh0013dx (LA-M798P) LDO does not rise
СообщениеДобавлено: 02 апр 2024, 20:12
So I took a closer look at the circuitry and saw interconnectivity between EC_ON,EN1,EN2(ENLDO_3V5V) so I desoldered the EC controller and retested all the resistors and caps again and by chance noticed that PC522 was not shorted but had a slight leakage, and then it all made sense... so after replacing PC522 and resoldering back the EC controller, the laptop came back to life... I'm posting my diagnosis here, maybe it will save someone the hassle in the near future.. :nez-nayu:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Q5WV1 rev.2.0 (LA-7912P) does not light any LED panel, not power
eletmoraes
21 апр 2016, 11:32
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. hp envy x360 15-fh (la-m798p) Помогите опознать Шим
klient
26 мар 2024, 19:20
Serguz05 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dablbdmb8e0 rev e (toshiba sat l755) does not turn on
в форуме Toshiba
alexasha8311
31 май 2014, 09:38
alexasha8311 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. M4600 (CN-0605CY) Does not start
в форуме Dell
iddark
08 авг 2019, 19:25
iddark Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Viewsonic VG2030WM does not recognized DVI & VGA inputs
в форуме ViewSonic
latitude
28 ноя 2015, 15:53
hdd8181 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 42
