https://vlab.su/
HP Envy M6 (QCL51 LA-8714P) indentification of componet
https://vlab.su/viewtopic.php?f=53&t=23969
Страница 1 из 1
abuholm [ 25 авг 2014, 17:45 ]
Заголовок сообщения:  HP Envy M6 (QCL51 LA-8714P) indentification of componet
Hi everyone, this laptop came in with burnt capacitors near PQ105 and shorted PQ102. After repalcing I noticed 19v present but no 3.3v or 5v present and no short-circuit. PU301 has only 19v going to pin16 and 4.5v on pin 13 but all the rest of the pins have 0v so I suspect the ic to be faulty.The ic has EM J7 written on it. I suspect it to be similar to TPS51125 but I want confirmation. Thank you.
kotnatan [ 25 авг 2014, 18:02 ]
Заголовок сообщения:  Re: HP Envy M6 (QCL51 LA-8714P) indentification of componet
RT8205L
siberian [ 25 авг 2014, 19:51 ]
kotnatan писал(а):
RT8205L/M
RT8205L, без "/M"
kotnatan [ 25 авг 2014, 19:57 ]
siberian писал(а):
RT8205L, без "/M"
согласен , так как RT8205M - обозначение "EN="
исправил свой "косяк" :-):
abuholm [ 25 авг 2014, 20:14 ]
Thanks for the responses, is there a possibility that I can use TPS51125?
kotnatan [ 25 авг 2014, 20:39 ]
whether such a change is to work on the this platform QCL51 LA-8714P - I do not know :nez-nayu:
abuholm [ 26 авг 2014, 11:30 ]
Ok thanks, I will try it and post results.
abuholm [ 29 авг 2014, 01:29 ]
Hi everyone, I replaced the faulty chip with TPS51125 and it worked.. :ya_hoo_oo: . The problem with the laptop was short on 19v RAIL. The faulty components was shorted caps around PQ105, shorted PQ102 and faulty PU103 which I replace with TPS51152. Hope it helps someone since there are no schematics for this model.. :a_g_a:
http://www.phpbb.com/
