Текущее время: 01 май 2024, 02:57
Страница 1 из 1 [ 1 сообщение ] |
sumsumlb
Заголовок сообщения: HP Notebook Support Utility – Password Unlock6 Добавлено: 15 май 2011, 15:30 |
Зарегистрирован: 06 ноя 2010, 02:48 Наличности на руках: 1,304.05
Сообщения: 85 Откуда: Beirut
UNLOCK6 is a tool that will allow an HP Authorized service partner to clear the password in specific HP notebooks with an OEM BIOS. (HP Compaq nx7200 Notebook PC, HP Pavilion dv4000 Notebook PC, HP Pavilion dv4100 Notebook PC, HP Pavilion dv4200 Notebook PC, Compaq Presario V4000 Notebook PC, Compaq Presario V4100 Notebook PC, Compaq Presario V4200 Etc...)
How to Use:
If the notebook you are servicing has an unknown password, follow these steps to clear the password. These steps also clear CMOS:
1. Enter an incorrect password and press enter. 2. Repeat Step 1 two times. After the third entry of the incorrect password, the notebook responds with a "system Disabled" message and provides an override password. 3. On working computer, access MS/DOS by clicking Start > All Programs > Accessories > Command Prompt. 4. Change directories to C:\Swsetup\Unlock6 5. Enter "unlock6 xxxxx 0", where "xxxxx" is the password generated by the notebook in Step 2. The notebook responds with another system-generated password. This password can be used to unlock the notebook and reset the password. *Detailed usage and support information can be found by reviewing the included “readme.txt” file.
