Текущее время: 30 апр 2024, 23:33
 Заголовок сообщения: Probook 4540s (Rocky-Itel) Plugged in not charging
СообщениеДобавлено: 31 янв 2015, 20:13
Hi to everyone.
Laptop brought in windows says: Plugged in not charging. Battery changed by new one, SIO(KBC1126-NU) & Supercharger(BQ24736) changed by new one. BIOS sewed by True and working. Charge MOSFETs changed. any one know where I must Dig? (I found similar schematic and 3rd pin on DCIN(LIMIT_SIGNAL) seems faulty.)
Don't give up without the fight.
 Заголовок сообщения: Re: Probook 4540s (Rocky-Itel) Plugged in not charging
СообщениеДобавлено: 01 фев 2015, 10:20
Just any idea where to dig??? In dell laptops I know there is a problem in PSID(adaptor Pi
) but in hp??like dell must check adaptor pin route to SIO???? Plugged in not charging what means??? Means battery derected or not??? Adaptor is ok or not??? Somebody plz break the silent.
СообщениеДобавлено: 01 фев 2015, 11:06
Power supply checked ?
At the central contact no break ?
Check interchanged , if possible.
СообщениеДобавлено: 01 фев 2015, 11:15
adaptor changed by new one
---------- Добавлено спустя 2 часа 44 минуты 9 секунд: ----------
https://onedrive.live.com/redir?resid=B ... file%2cpdf
There is a similar and good schematic for this platform.
1.I measured Adapter pin(90W) and it was ~ 19V, but when I plugged adapter jack in DCIN1(schematics) 3rd pin(LIMIT_SIGNAL) decrease to 3.4V, is it normal??(I thinks because of D8201.
2.By tracking LIMIT_SIGNAL , Q3802 seems suspicious. Gate=7.7 Source=3.3 but no voltage on Drain, I connect Source to Drain by wire so MB not starts! Wire removed and 3.3V tossed on Drain MB start but everything is same( charge(Amber) LED if off ), and in windows says: Plugged in not charging.
СообщениеДобавлено: 02 фев 2015, 20:52
The normal level of 3dr pin 6.5v.
check D8201.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Probook 4540s (Rocky-Itel) не запускается, через 4 сек всё глохнет совсем.
IvanM
28 фев 2015, 12:17
IvanM Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Probook 4540s (Rocky-Itel) ?видеочип сгорел?
IvanM
26 ноя 2015, 17:36
В этой теме нет новых непрочитанных сообщений. HP Probook 4540s (Rocky-Itel) каждые 5-10 min CD ROM издает шум
IvanM
02 дек 2015, 23:08
FearCult Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
kosmo555
18
1761
28 янв 2021, 15:39
kosmo555 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Probook 4540S (Wistron Rocky Intel ) Зеленое изо.
elf22
3573
15 сен 2014, 21:37
elf22 Перейти к последнему сообщению
Сейчас этот форум просматривают: uran и гости: 45
