Текущее время: 21 май 2024, 14:07
sergunis
Заголовок сообщения: Re: Pavillion DV6000-DV9000 turns on and then off after 2 se Добавлено: 09 июн 2011, 20:54 |
aikiotto писал(а): Morning guys!
I would like to share a simple solution I've used with a few laptops of these models (Turion processors) the symptomps as described are , the laptop turns on then after a couple seconds shuts down itself , no video at all on the laptop screen or external monitor.
Overheat on the GPU (NVIDIA G3) causes the chip to loose contact with the board , a reflow (circular motions with a medium/small nozzle at 300ºF during 5 minutes , previously applying resin flux with a syringe) on this chip restores the contacts and your laptop will be good to go.
Dont forget to througly clean fans and replace thermal paste/pads before closing it. Change the Northbridge, the heating does not help
sergunis
Заголовок сообщения: Re: Pavillion DV6000-DV9000 turns on and then off after 2 se Добавлено: 10 июн 2011, 09:29 |
aikiotto писал(а): Certainly the ideal choice would be a replacement of the Gpu/NBridge along with a slight mod to the case to improve airflow and perhaps tweaking the ACPI DSDT table to lower the temp threshold to wich the fans jumps to 100% , but a BGA replacement requires a bit of more hardware and not everybody is ready to mess with the table , so I was merely pointing a just another choice to deal with this issue that might last more or less depending on the user care/treatment of the lappy.
Some people even mention adding copper shingles , but i never trusted what those might do to the processor/gpu in question. This is not the answer, but only to postpone the inevitable for a short time, the copper plate in this case will not help ...... if there is no specialized equipment, go to the service center ....
cyysky
Заголовок сообщения: Re: Pavillion DV6000-DV9000 turns on and then off after 2 se Добавлено: 29 июн 2011, 15:40 |
Зарегистрирован: 16 мар 2011, 04:40 Наличности на руках: 66.30
Сообщения: 12 Откуда: malaysia
sergunis писал(а): aikiotto писал(а): Certainly the ideal choice would be a replacement of the Gpu/NBridge along with a slight mod to the case to improve airflow and perhaps tweaking the ACPI DSDT table to lower the temp threshold to wich the fans jumps to 100% , but a BGA replacement requires a bit of more hardware and not everybody is ready to mess with the table , so I was merely pointing a just another choice to deal with this issue that might last more or less depending on the user care/treatment of the lappy.
Some people even mention adding copper shingles , but i never trusted what those might do to the processor/gpu in question. This is not the answer, but only to postpone the inevitable for a short time, the copper plate in this case will not help ...... if there is no specialized equipment, go to the service center .... I agree, reflow mean not stable.
