Текущее время: 19 апр 2024, 19:08
 Заголовок сообщения: HP Elitebook 8560P (CURE-UMA_HR_HPB) it shut down after 30 mins
СообщениеДобавлено: 09 апр 2015, 17:11
Hi all
this laptop dose not show anything on its display , I have used bios dump at
vlab.su/download/file.php?id=34045
ok now it works but after 30 mins it shut down , so any one could provide me a dump with clear Me region
 Заголовок сообщения: Re: HP Elitebook 8560P (CURE-UMA_HR_HPB) it shut down after 30 mins
СообщениеДобавлено: 10 апр 2015, 02:17
Hi. If you're thiknking that your problem from bios, you should update bios from official hp site by utility. Are you replace the CPU? Usually, if motherboard turned off after 30 minutes, it may indicates unsupported CPU.
СообщениеДобавлено: 10 мар 2016, 20:25
i have some problem with BIOS. I have changed CPU and still same 30Mins and off. I have old bios but with admin password and is working ok - no auto off after 30 min.
Also please do not write funny advisories like download bios from HP, update BIOS its always only region not whole IMAGE...
So still looking for bios...
СообщениеДобавлено: 10 мар 2016, 22:53
Make it from your BIOS
viewtopic.php?p=245179#p245179
http://savepic.net/6252240.htm
СообщениеДобавлено: 15 мар 2016, 14:09
@Sergej
Cleaning ME its not the solution i want to have fully working laptop with me/AMT. I can make own bios but the question is why the hell loosing so much time instead of 1 click on proper download bios dump. I'll upload soon normal clean 8560p Clean Dump.
Also Me region often starts with "20 20 80 0F 40"
Have a nice day !
СообщениеДобавлено: 22 июн 2017, 21:03
Have you made working bios for this platform? I have the same problem, but to make bios with clear me for me is not enough knowledge.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. probook 6560b (cure dis hr hpb) не вкл
сергей петрович
3323
13 янв 2020, 15:56
Mishabr Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP ELITEBOOK 8560P (CURE-UMA_HR_HPB) No SOUND(Audio)
brogdan
3686
16 июл 2015, 14:53
brogdan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteBook 8560p (CURE-DIS_HR_HPB MV_MB_V1) проблемы с ME регионом
sevastd
16
2100
05 мар 2021, 18:39
sevastd Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. 8560p (Cure-uma) Проблема с биосом и ме
Raimondas
3782
15 июл 2017, 12:53
Raimondas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 5552 (Compal LA-6552p) shut down by itself after few seconds
latitude
3240
12 фев 2015, 09:28
latitude Перейти к последнему сообщению
Сейчас этот форум просматривают: mantza, once83, S3rega и гости: 35
