Текущее время: 18 май 2024, 23:08
FRD
Заголовок сообщения: Re: Compaq 6735s (6050A2235601-MB-A03) 1st MOSFET doesn't turn on Добавлено: 05 янв 2016, 21:32 |
Зарегистрирован: 12 май 2014, 21:17 Наличности на руках: 70.07
Сообщения: 50 Откуда: Iran
novapc писал(а): Chek these signals: ADP_EN# must be 0V. BUTCAL# must be 0V. Thanks for the reply. ADP_EN# is 19v BATCAL# is 18.3v in order to operate normally, should they be zero?
novapc
Заголовок сообщения: Re: Compaq 6735s (6050A2235601-MB-A03) 1st MOSFET doesn't turn on Добавлено: 06 янв 2016, 11:32 |
Зарегистрирован: 26 окт 2013, 12:31 Наличности на руках: 992.13
Сообщения: 768 Откуда: г. Рубежное
FRD писал(а): ADP_EN# is 19v BATCAL# is 18.3v
in order to operate normally, should they be zero? I think so. Update BIOS, and try to chek CHGCTRL_3. May by KBC1091 (118 pin) do not generate this one.
