G62-b13SL (PM_I_HPC_S MV_MB_V3) CPU overheat after disabling discrete GPU https://vlab.su/viewtopic.php?f=53&t=48434 |
giofrida [ 11 июл 2016, 15:06 ] | |
Заголовок сообщения: | G62-b13SL (PM_I_HPC_S MV_MB_V3) CPU overheat after disabling discrete GPU [РЕШЕНО] |
Hello and congratulations for this great forum full of knowledge! ![]() Here is my problem: I have disabled the discrete ATI GPU by removing PJ19 jumper (+VPCIE) and PL8 coil (+VDD_CORE) and swapping RI55 with RI51 and RI53 with RI56 (SKU: SG_PARK => UMA). The computer does not detect ATI GPU anymore, but the CPU runs at 55°C and up when in idle. I then cleaned the fan and heatsink and applied another thermal paste, but nothing changed. I have also tried to flash the BIOS+EC (F.48) again from Windows and during startup (by holding Win+B). Still the situation has not changed. I think the problem is somewhere else. I believe someone could lead me to the solution Thank you all in advance! |
giofrida [ 03 авг 2016, 12:50 ] | |
Заголовок сообщения: | Re: G62-b13SL (PM_I_HPC_S MV_MB_V3) CPU overheat after disabling discrete GPU |
Solved! The problem was the heatsink itself: the heatpipe at its end was broken. After having replaced it the problem was gone. |
