Текущее время: 01 май 2024, 05:56
 Заголовок сообщения: Hp Omni 120 (DAOWJ7MB6E0) no video and no response.
СообщениеДобавлено: 26 сен 2016, 12:34
Hp Omni 120 DAOWJ7MB6E0
Hi,
I am trying to repair a hybrid desktop/notebook without image.
The computer stars to function as soon as 19v. connector is plugged.
The power consumption from 19v. adapter is 1500 milliamps.
It has an Intel core ix and has two bios chips, that I already have re-progarammed.
There seems that there is not schematic for this board, and is very difficult to follow voltages an signals.
Both bios chips has pulses in its pin 1 to select device, but seems that it hangs during POST.
There is no beeps booting without ram memories.
All pwm voltages seems good, cmos battery is also good, and cpu/ chipset gets a normal temperature.
Does anyone knows if this mobo has to beep without memory?
What do you think?
 Заголовок сообщения: Re: Hp Omni 120 (DAOWJ7MB6E0) no video and no response.
СообщениеДобавлено: 27 сен 2016, 22:06
I have made a mistake with the motherboard model number, the correct model is DA0WJ5MB6F0 rev. F :-(
СообщениеДобавлено: 30 сен 2016, 20:08
motherboard: DA0WJ5MB6F0 rev. F (Hp Omni 120 AIO)
Not all voltages are present, +VGFX_CORE is missing due to pwm circuit (NCP5911 and associate mosfet) is not working.
This NCP5911 chip, is controlled by a NCP6131 pwm chip, (IMVP7 1-, 2-, 3-Phase CPU Controller + 1-Phase GPU Controller) but is not clear, (seeing in other schematics with same chips) how this voltage is controlled. (which signal)
A capture from FOXCONN CHICAGO_HR_HPC schematic, is attached showing part of this circuit.
Thanks for some feedback.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC ( 120-1202er ) (DA0WJ5MB6F0 REV: F) Нужен дамп BIOS+EC
fulgen
23 апр 2015, 17:02
Дмитрий Никулин Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC (120-1200en) (Quanta WJ5 (DA0WJ5MB6F0 REV: F )) проблема с драйвером видео от intel
DmitryKZ
25 янв 2016, 10:36
DmitryKZ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC (120-1204er) Полосы артефакты до загрузки ОС
vlsotov
03 апр 2023, 17:12
vlsotov Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. omni 120 aio pc 120-1106er (quanta wj5 rev f) Изредка загружается
в форуме HP
bvd
18 апр 2024, 18:47
DmitriyDDD Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony SVE1511C5E (Quanta HK5, MBX-269 REV-F) Looping On and Off and No video on LCD
в форуме Sony
mun4o
05 мар 2015, 19:39
mun4o Перейти к последнему сообщению
Сейчас этот форум просматривают: Di.K, mohammedsf и гости: 39
