HP 8460p (6050a2398701-mb-a02) Stuck at HP logo and Caps Lock Blinks 5 times https://vlab.su/viewtopic.php?f=53&t=57663 |
FRD [ 23 фев 2017, 15:18 ] | |
Заголовок сообщения: | HP 8460p (6050a2398701-mb-a02) Stuck at HP logo and Caps Lock Blinks 5 times |
Hi As the topic title says, there is a HP 8460p that turns on but is stuck at HP logo and Caps lock and Num lock blink 5 times. Any body has any guesses what the problem can be? I have tried with two different BIOS dumps with no luck. Thanks in advance. |
recordsman [ 24 фев 2017, 12:31 ] | |
Заголовок сообщения: | Re: HP 8460p (6050a2398701-mb-a02) Stuck at HP logo and Caps Lock Blinks 5 times |
FRD писал(а): Caps lock and Num lock blink 5 times hi there try to extract and flash or SD cards, Cd disk also try to press Esc or F9 for check download sources in other way you must disassembly laptop for measure general voltage ranges |
FRD [ 24 фев 2017, 12:46 ] | |
recordsman писал(а): FRD писал(а): Caps lock and Num lock blink 5 times hi there try to extract and flash or SD cards, Cd disk also try to press Esc or F9 for check download sources in other way you must disassembly laptop for measure general voltage ranges Thanks for the answer. I have disassembled the laptop completely, there isn't any other external peripheral connected to laptop, Checked with another RAM, CPU, .... Also have flashed the BIOS with 2 different dumps. Will try to measure voltages and see if anything interesting. |
soscomputer2008 [ 12 апр 2017, 10:39 ] | |
5 blink are not related to the bios but it is a general system error |
