Заголовок сообщения: HP Pavilion 15-au062nr (DAG34AMB6D0 Rev D) Administrator or Power On Password clearing
Добавлено: 14 мар 2017, 19:31
Зарегистрирован: 29 ноя 2012, 22:23 Наличности на руках: 0.01 Сообщения: 172 Откуда: Kenya
Hi,
Tried to clear the password but after reprogramming with another dump, it turns on blinks 3 times then restarts blinks 5 times the 3 times in quick succession with nothing displayed on the screen. Reprogramming with its original code restores display but the password is not cleared. Any help will be appriciated.
Regards.
paki
Заголовок сообщения: Re: HP Pavilion 15-au062nr (DAG34AMB6D0 Rev D) Administrator or Power On Password clearing
Добавлено: 15 мар 2017, 12:01
Зарегистрирован: 08 фев 2015, 12:55 Наличности на руках: 124.18 Сообщения: 176 Откуда: Самара
Try this
bridx
Добавлено: 19 мар 2017, 22:08
paki писал(а):
Try this
Thank you. I had tried this file from HP also 08209F26.bin but all behave the same, blinking caps without display. I managed to clear the password using a master password.
Сейчас этот форум просматривают: shardyko63 и гости: 24
