Текущее время: 29 мар 2024, 17:51
amennone
Заголовок сообщения: HP Pavilion g6-1277sl (DA0R23MB6D0) non accende Добавлено: 06 фев 2018, 23:21 |
Зарегистрирован: 06 фев 2018, 22:46 Наличности на руках: 11.00
Сообщения: 6 Откуда: salerno italy
Scheda madre : Da0R23MB6D0 rev.D
Difetto : Dopo aver spento il portatile , alla successiva accensione , non da segni di vita . Alimentazione 19 v presente , nessun corto circuito evidenziato . tensioni sul KBC : pin 64 ov7 pin 65 2v8 pin 19 ho una tensione di 3v3 , con la pressione del tasto power va a 0 volts per poi ritornare a 3v3 quando rilascio il tasto power pin 127 3v3 pin 123 0v pin 101 3v3 pin 86 2v8 pin 13 0v grazie per l'aiuto [mod="MSF113"]Use english![/mod]
Posted after 1 hour 10 minutes 18 seconds: Motherboard: Da0R23MB6D0 rev.D
Defect: After turning off the laptop, at the next power on, no signs of life. Power supply 19 v present, no short circuit highlighted. Tensions on the KBC: pin 64 0v7 pin 65 2v8 pin 19 I have a voltage of 3v3, with the pressure of the power button it goes to 0 volts and then returns to 3v3 when the power button is released pin 127 3v3 pin 123 0v pin 101 3v3 pin 86 2v8 pin 13 0v4 with pressure key power 0volts pin 95 18v always present pin 90 3v3, press power button 0 volts release power button 3v3 pin 6 0v3 with press power button or volts pin 16 0v3 with press power key or volts pin 98 0 volts, I noticed that by removing power I have a voltage of 18 volts pin 99 idem pin 98 Thanks for your help
planetoxod
Заголовок сообщения: Re: HP Pavilion g6-1277sl (DA0R23MB6D0) non accende Добавлено: 07 фев 2018, 01:26 |
Зарегистрирован: 06 ноя 2015, 01:16 Наличности на руках: 4,584.87
Сообщения: 2849 Откуда: Липецк
amennone писал(а): pin 95 18v always present is that true ?
_________________ Помогли - поблагодари.
amennone
Заголовок сообщения: Re: HP Pavilion g6-1277sl (DA0R23MB6D0) non accende Добавлено: 07 фев 2018, 02:02 |
planetoxod писал(а): amennone писал(а): pin 95 18v always present is that true ? yes
