hi guys i have problem with hp8570w it turn on but when logo hp show it turn off i wrote bios chenge cpu & ram & graphic card bu noting change finaly i chane PCH with new one but again nothing cheng and it turn off when logo come...
Check if DrMOS does not switch off thermally. I bet on the power section. If DrMos heats up, use a multimeter to check for a short circuit, a diode may also be a problem. You must measure.
