Текущее время: 28 апр 2024, 15:24
 Заголовок сообщения: HP ProBook 1040 G4 (DA0Y0UMBAD0) Audio issues
СообщениеДобавлено: 20 янв 2020, 17:51
Hello everyone, I'm having audio issues. When the laptop boots into windows, there is a loud whining noise from the two front main speakers (only happens when in windows). I replaced both smart audio amplifier chips (TFA9891) but the problem remains the same.Bios updates and various drivers have not helped (default windows drivers only activates the two small speakers above the keyboard and those are OK) .So I decided to replace the audio codec (CX9602-11Z) with a brand new chip but surprisingly, the PC does not detect any audio device, but when I revert back to the old chip, audio is detected and I don't understand because the new chip was perfectly placed on the board and part number is same. I want to know if something has to be done when a new codec is installed or whether the new chip is faulty? (all chips bought from supplier always worked). Any help will be appreciated.
 Заголовок сообщения: Re: HP ProBook 1040 G4 (DA0Y0UMBAD0) Audio issues
СообщениеДобавлено: 20 янв 2020, 21:24
"New" codec may be defective. At first check codec power supply with oscilloscope and all points from amplifier outputs to speakers, then try few another codecs.
СообщениеДобавлено: 21 янв 2020, 06:12
Thanks for reply. luckly I bought 2 chips so will solder 2nd chip and see. Checking pinouts on codec is going to be impossible due to the fact that schematic is unavailable and I've searched in vain for a datasheet. I will be very grateful if someone can point me to a schematic with codec CX9602-11Z.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Elitebook 1040 G4 (DA0Y0UMBAD0) нужен BIOS
atalarc
14 апр 2021, 11:24
atalarc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. G4 EliteBook 1040 (DA0Y0UMBAD0 REV.D) нет инициализации
mumbl
04 ноя 2021, 21:47
Rein Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 15-p076na ( DAY11AMB6E0) Conversion form DIS to UMA issues
abuholm
09 окт 2017, 18:07
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1502 (820-4924-A) Backlight Sensor Issues
в форуме Apple
abuholm
20 сен 2018, 03:02
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI CX61 (MS-16GD1) graphics issues
в форуме MSI
andromedax
26 сен 2019, 21:59
andromedax Перейти к последнему сообщению
Сейчас этот форум просматривают: Alex7GT, shmyzdrek и гости: 41
