Заголовок сообщения: Toshiba C50-B (da0blimb6f0 rev: f) No display and unit turns itself on, fan ot working properly Cpu gets hot
Добавлено: 20 апр 2015, 14:57
Зарегистрирован: 14 мар 2013, 01:33 Наличности на руках: 1.13 Сообщения: 106 Откуда: Ireland
The unit switches itself on even if on battery or adapter, you can turn it off but its turns back on itself. Fan spins for approx 1 second and doesn't spin again regardless of Cpu temp.Laptop only draws .5A and 1.5a when the battery is inserted. Cpu get very hot I cna find most voltages 3.3v/5v/1.6v/1.7v. I cannot find the DDr .75v termination voltages.The board has integrated i5 cpu. I have also replaced the sio and also reflashed the bios but same issues remain. Is there a schematic out there that would help?.
Сейчас этот форум просматривают: alex_2576 и гости: 3
