Текущее время: 04 июн 2024, 10:18
andromedax
Заголовок сообщения: Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post) Добавлено: 20 июн 2015, 19:12 |
Сообщения: 262 Откуда: Alicante, Spain
This motherboard has 3.3 & 5 volts OK, and charges the "main" battery perfectly, but it hangs before any voltage came to the cpu. (same occur with or without any ram)
The bios have been reprogramed already, and I can see some pulses at pin 1,5,2,6 of GD25Q64B 64Mbytes flash chip, but only within one second. (U17 (I2C memory) has pulses but also within one second)
There is 3.3 volts in power button, but nothing happen when I press it. (only voltage drops to zero)
I said "main" battery, but there is no other battery or "super capacitor" for c-mos feeding.
Any schematic which can I use for reference?
I will appreciated any help.
andromedax
Заголовок сообщения: Re: Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post) Добавлено: 21 июн 2015, 15:39 |
s0ulbl4d3 писал(а): I think you should try to flash the correct bios, or edit bios As I mention, I have reprogramed the bios: download/file.php?id=53118Why edit bios? Regards.
andromedax
Заголовок сообщения: Re: Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post) Добавлено: 27 июн 2015, 21:51 |
darutis писал(а): My working board is (DA0BLIMB6F0 Rev.F) or not working is (DA0BLIMB6E0 Rev.E). But i don't see difference. Does one of them have c-mos battery? It is something I can not understand.
