L50D-C (DA0BLTMB8F0 Rev F) Discrete to UMA Successful https://vlab.su/viewtopic.php?f=54&t=106825 |
mohammedsf [ 13 сен 2020, 05:35 ] | |
Заголовок сообщения: | L50D-C (DA0BLTMB8F0 Rev F) Discrete to UMA Successful |
Hi, I've got a L50D-C with R5-M330 GPU that won't accept it's drivers (screen goes out during driver installation then windows freezes while loading after forcing to restart) Symptoms of a dead GPU it is, so I've went to UMA conversion but didn't find any schematics/boardview/info anywhere.. After some experiment I've found the solution and decided to share, it was quite simple, just remove the GPU's coil and PWM chip (isl62771) |
Danila. [ 13 сен 2020, 12:36 ] | |
Заголовок сообщения: | Re: L50D-C (DA0BLTMB8F0 Rev F) Discrete to UMA Successful |
Mustn't remove PWM CHIP. You just need to remove resistor from VCC pin this chip. (if it is here), or cut VCC trace |
mohammedsf [ 15 сен 2020, 02:24 ] | |
Danila. писал(а): Mustn't remove PWM CHIP. You just need to remove resistor from VCC pin this chip. (if it is here), or cut VCC trace I prefer to salvage the isl chip rather than salvaging a resistor or keeping it useless on the board Thank you for your replay,, |
