Текущее время: 01 май 2024, 03:05
abuholm
Заголовок сообщения: Toshiba A215 (Inventec MW10A - 6050A2127101_MB-A02 ) Does not respond to the power switch Добавлено: 03 ноя 2013, 01:33 |
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 30.00
Сообщения: 198 Откуда: Ghana
I really need help on this because i have run out of ideas. +V3A, +V5A, +V1.2A is present, as well as 3.3v to power switch which drops to 0v when pressed. Battery charges. LID_SW#_3 = 0v, RSMRST# = 0v, SLP_S3#_3R = 0v, SLP_S5#_3R = 0v, EC_PWRSW# = 3v, +V5AUXON is present. There is no short on any of the signals or coils. I have reprogrammed the bios but the problem still remains.What should I check next?
Заголовок сообщения: Re: Toshiba A215 (Inventec MW10A - 6050A2127101_MB-A02 ) Does not respond to the power switch Добавлено: 05 ноя 2013, 08:58 |
LID_SW#_3 = 0v, RSMRST# = 0v, SLP_S3#_3R = 0v, SLP_S5#_3R = 0v all BAD. It must be all 3.3V. Check the resistance to ground of this signals.
