Текущее время: 26 апр 2024, 17:24
 Заголовок сообщения: Toshiba A205-S5825 (ISKAA LA-3481P Rev : 2A) regular shut down issue at start up
СообщениеДобавлено: 13 май 2014, 22:34
Hi! An urgent help is needed for Toshiba A205-S5825 regular shut down issue.
Steps already taken :
1-cleaned fan system (was a little dusty but not clogged), removed dried paste and applied new one to CPU and GPU.
2-Tried naked mobo with a working ram, CPU, KB and Lcd display, enter bios screen, lap always shut down after about 1'50s.
3- Scanned mobo with an infra-red thermometer, Max temperature registred 42° at SB, so no heat issue.
4- Checked Thermal Sensor ADM1032ARM :
VDD : 3Vs
D+ 2.38V
D- 0v
EC_SMB_CK2 and _DA2 : 5.6V each
pin 4 "Therm#" and 6 "Alert#" not connected.
Please note that CPU of A205-S5825 series doesn't use big "Nec-Tokin cap" but 330uf small caps.
Also Tried with Mobo +ram +fan but without CPU it also shut down at about same time.
Has any one dealt with the same issue, or any clue as where to dig further
Thank you
 Заголовок сообщения: Re: Toshiba A205-S5825 (ISKAA LA-3481P Rev : 2A) regular shut down issue at start up
СообщениеДобавлено: 17 май 2014, 22:05
22 had already viewed my post, but no reply.
Still waiting for any suggestion from colleagues. Hope not to be disappointed.
СообщениеДобавлено: 28 май 2014, 10:52
1 st step try change bios firmware
2 - try change your charger
3 - may be you have a cracked USB port on mainboard
СообщениеДобавлено: 28 май 2014, 17:39
1-Updating bios might be risky, as lap is shutting down after 1'50s (see my 1st post). Would it be possible within this short time ?
2- Changing charger is among 1st things I did to no avail.
3- Checked no visual crack and no short at usb ports.
Any new suggestion or comment is welcome.
Thank you.
В этой теме нет новых непрочитанных сообщений. Toshiba A200 (Compal ISKAA LA-3481P Rev. 2A) Проблема с питанием
в форуме Toshiba
visla
1875
19 июн 2018, 12:50
visla Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba a 200 (iskaa la-3481p) Нет изображения на экране.
в форуме Toshiba
rfgs
26 май 2014, 10:18
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satallite A205-S5000 (LA-3481P Rev.2.0) Включается и выключается
в форуме Toshiba
rainstorm_tj
3458
28 май 2014, 14:22
rainstorm_tj Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A200 (ISKAA LA-3481P REV 2A) рестартует
в форуме Toshiba
apollo
13 июл 2014, 20:18
ars44 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. compal iskaa la-3481p rev 2 boardview
pavelp14
22 мар 2023, 23:12
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 18
