Заголовок сообщения: L770-14c (BS_R/TK_R rev:2.1) Powers off after 1 second
Добавлено: 26 май 2015, 03:01
Зарегистрирован: 14 мар 2013, 01:33 Наличности на руках: 1.13 Сообщения: 106 Откуда: Ireland
Hi I have a L770-14c 69n0y3m1gb01-01 BS_R/TK_R rev:2.1 P/N:08N1-0NA1Q00 I cant locate a schematic or boardview for this model. Initially laptop was dead I found a short circuit capacitor on the 19v line after removing unit powers up for 1 sec, draws .5a current then shuts off again. I checked all the coils and no short circuit. the only issue I can find is the capacitor in the picture (2) is reading short circuit and when lifted short circuit is still on the pads. This is with or without a cpu present. I cannot locate the source of the short and injecting power into it doesnt cause any component to get hot.
Any help is appreciated.
and555
Заголовок сообщения: Re: L770-14c (BS_R/TK_R rev:2.1) Powers off after 1 second
Добавлено: 29 май 2015, 21:06
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09 Сообщения: 285 Откуда: Indonesia
did you already checked the output of N-Channel mosfet ? for the illustratiion, see below picture: below picture is Edwards Power Block Diagram (HP Mini 110 Schematic),
Вложение:
_________________ لا إله إلا الله محمد رسول الله
s0ulbl4d3
Добавлено: 06 июл 2015, 15:57
Зарегистрирован: 17 июн 2015, 18:47 Наличности на руках: 0.00 Сообщения: 15 Откуда: indonesia
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 23
