Текущее время: 16 апр 2024, 11:01
 Заголовок сообщения: Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post)
СообщениеДобавлено: 20 июн 2015, 19:12
This motherboard has 3.3 & 5 volts OK, and charges the "main" battery perfectly, but it hangs before any voltage came to the cpu. (same occur with or without any ram)
The bios have been reprogramed already, and I can see some pulses at pin 1,5,2,6 of GD25Q64B 64Mbytes flash chip, but only within one second. (U17 (I2C memory) has pulses but also within one second)
There is 3.3 volts in power button, but nothing happen when I press it. (only voltage drops to zero)
I said "main" battery, but there is no other battery or "super capacitor" for c-mos feeding.
Any schematic which can I use for reference?
I will appreciated any help.
 Заголовок сообщения: Re: Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post)
СообщениеДобавлено: 21 июн 2015, 11:58
I think you should try to flash the correct bios, or edit bios
СообщениеДобавлено: 21 июн 2015, 15:39
As I mention, I have reprogramed the bios:
download/file.php?id=53118
Why edit bios?
Regards.
СообщениеДобавлено: 27 июн 2015, 21:30
I have got such problems. I have one running and a few broken motherboard. They have 3.3V and 5V LDO and also to the CPU comes 1,36v and 2,4v. But he did not start either with battery or AC. Compare with a fully functional board, but did not find the difference. In desperation changed from I7 CPU (i7-4500U) to I5. The result was positive. But I noticed that it does not start when I inserted the battery, without battery ok. Further even more interesting, now it starts from the batteries, but does not start from the AC. Already a removed CPU (i7-4500u) laid on another base plate which had a CPU - it was fully functioning without any defects. Now I continue to think. Another thing he has to start without U17 (I2C) or running the image without it I do not know. Also PWRGOOD he lifts only is run. If you have any thoughts to share. BIOS also rejected as on other plates if worked fine.
My working board is (DA0BLIMB6F0 Rev.F) or not working is (DA0BLIMB6E0 Rev.E). But i don't see difference.
Working bios from toshiba site
СообщениеДобавлено: 27 июн 2015, 21:51
Does one of them have c-mos battery?
It is something I can not understand.
СообщениеДобавлено: 27 июн 2015, 21:55
They do not have the CMOS battery, as far as I understand their CMOS battery is the battery. Just checked another BIOS. If I need to roll over. I checked on BLI and Blid platform.
СообщениеДобавлено: 01 дек 2019, 20:04
There is no CMOS battery on this paltform, main laptop battery produces +VCC_RTC
В этой теме нет новых непрочитанных сообщений. Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) нужна схема
peit
13 июл 2017, 20:26
guar33 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs.
в форуме Toshiba
andromedax
2133
21 сен 2018, 13:07
Vertyanov_SS Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Satellite L50-B-2DP (da0blimb6f0 REV: F) опознать элементы
в форуме Toshiba
peit
25 май 2017, 15:30
METALLSRJ Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Satellite-L50 (DA0BLIMB6F0 Rev.F) Запуск через раз
в форуме Toshiba
peit
20 июл 2017, 22:19
seregapplk Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite s55t-B (DA0BLIMB6F0) Выключается на заставке биоса
в форуме Toshiba
kalya
18
5018
03 мар 2018, 18:21
kalya Перейти к последнему сообщению
