Today I got Toshiba Satellite P750 not turning on it was Nescafe damage the costumer was drinking Nescafe and the cup fall on it the turned off
I did the following repairs 1- clean the board 2-tested voltages JPOWER 3.3, 5.0 volts are ok but when pressing Power button not turning on ! 3-Voltage on pin number 32 is 3.3v (ENE Chip) 4-voltage on pin 100 is 3.3 without pressing and with pressing the result it's not powering on
when pressing power button the voltage on ENE chip pin 32 becomes 0.0V but the PCH_RSMRST on pin 100 should come out after pressing the power button but in my situation the voltage is still appear even if I pressed or not
so please what should I do in this case ? it is Core i7 CPU !
