Текущее время: 19 апр 2024, 21:55
 Заголовок сообщения: Toshiba C50-A (C50-A-14W) mistake in cable soldering
СообщениеДобавлено: 10 окт 2016, 21:01
Hello, Im new on this forum.
I have some problem with my Toshiba
I had to replace power supply init cable and by mistake switched wires + and O and connect to the laptop causing damage.
Now I have laptop dead, no blinking or flashing LEDs - all dead.
Can you tell me or show in some way where can I find the fuse on the motherboard. I tried to find it near the power socket but there is no ordinary descriptions on the board, such as FUSE500 or something.
type of mainboard - motherboard pt10f uma rev 2.1
I guessing that the fuse is this vertical "thing" under the copper screw hole. Am I right?
 Заголовок сообщения: Re: Toshiba C50-A (C50-A-14W) mistake in cable soldering
СообщениеДобавлено: 10 окт 2016, 21:14
komar190 Q - is a fuse. To his right - inductance. They live?
СообщениеДобавлено: 10 окт 2016, 22:02
I don't have the scheme so I don't know if the fuse is open or short in normal state
Now is short when I check it with multimeter. Should I check it also when power is connected?
Is it a good way to check it in thermal test?
Spray with isporopanol and connect the power and check alcohol vaporing speed?
On this link there is some scheme of that motherboard but I don't have permission to save it because I'm newbie.
viewtopic.php?f=250&t=4928&p=330654&hilit=%2Apt10f%2A#p330654
After that I need for sure, check what is this fuse exactly to buy it.
СообщениеДобавлено: 10 окт 2016, 22:25
komar190 No scheme, only BoardView. Check your private messages.
В этой теме нет новых непрочитанных сообщений. куплю HP Pavilion 15-P Series LVDS Cable / LCD Cable Y14ALC140
в форуме Куплю | Buy
Dimonische
02 окт 2015, 13:55
Dimonische Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Satellite C660-14W (Compal 6842p) Не стартует, дисплей стал сиренево-розовым
в форуме Toshiba
vatnique66
31 окт 2017, 02:24
hardhaker Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. BGA soldering
disturbedl
05 июн 2014, 09:07
В этой теме нет новых непрочитанных сообщений. How can I test the parallel cable from the dot matrix printer to know if it's good?
eletmoraes
25 мар 2022, 20:23
Mishel01 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Куплю шлейф UX32VD-1A 2IN1 LVDS CABLE
serpyxa
17 фев 2015, 15:45
serpyxa Перейти к последнему сообщению
