Текущее время: 29 мар 2024, 02:01
 Заголовок сообщения: TOSHIBA Satellite L50D (DA0BLMMB6E0 Rev. E) No lcd image, hdmi ok.
СообщениеДобавлено: 29 дек 2017, 20:34
Hi,
This motherboard have image on hdmi output, but nothing in lcd.
It has all voltages in lvds connector, but no pulses in I2CC_SCL and I2CC_SDA. (measured with oscilloscope, only 3v. dc in both pines)
I have no schematic nor boardview, so I am using the LA-9532P for reference only.
LA-9532P has the same IC for LVDS translator (RTD2132), and this chip seems to establish communication with lcd screen bus, and lvds video signals. (it does not happen in this board)
Somebody can share the datasheet of RTD2132, or any help to solve this problem?
Thanks.
 Заголовок сообщения: Re: TOSHIBA Satellite L50D (DA0BLMMB6E0 Rev. E) No lcd image, hdmi ok.
СообщениеДобавлено: 30 дек 2017, 00:49
Measure resistance of TX lines on lcd connector, if it`ll differ- change translator
СообщениеДобавлено: 30 дек 2017, 19:54
There is no difference on tx lines on lcd connector, and no short circuit to gnd either. (ohms mode and diode mode are values as expected)
From pin 19 to pin 26 all measurements seems correct, with the exception of resistance reading between pairs of signals. (ie: resistance from pin 19 and pin 20 is is greater than 1 Mega-ohm)
It seems to me a bit higher than it should, as it is a low impedance output.
that's why I need the data sheet for RTD2132.
Regards.
Вложение:
СообщениеДобавлено: 20 янв 2018, 16:15
Have RTD2132 power and EN signal? If have - change translator. If have not - search why haven't.
Cyber_maniac
Люблю всё красивое, металличное...
TL866II, Vertyanov JIG, DS1102E, MFR PS1K, T12 и IR самоделки.
Если от образования в мозгах остались одни пробелы, то и мир вокруг чудесный, магический и непонятный.
В этой теме нет новых непрочитанных сообщений. MSI GE73VR (ms-16p11) no lcd/hdmi image
в форуме MSI
andromedax
09 авг 2019, 18:49
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. toshiba satellite M50D-A-118 (LA - A551P) don't show image in LCD
в форуме Toshiba
SpinNNN
25 фев 2017, 19:16
kmk Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite (l50d-c-19d) Снять пароль с BIOS
marksik
23
2952
25 фев 2021, 16:28
marksik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 17:25
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. tv LG 42PQ30R has image defect as attached image
в форуме PDP
eletmoraes
21 ноя 2019, 02:43
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
