Текущее время: 25 апр 2024, 02:51
 Заголовок сообщения: TOSHIBA Satellite c660 (LA-6842P) Identification Of Component
СообщениеДобавлено: 14 янв 2018, 13:34
Hi everyone, laptops powers on but for about 5secs and goes off and I found out that RUN voltages are not switching due to the absence of SUSP#. I found a rotten resistor around the PCH and would like to know the value..
 Заголовок сообщения: Re: TOSHIBA Satellite c660 (LA-6842P) Identification Of Component
СообщениеДобавлено: 14 янв 2018, 23:25
you have to use boardview and schematic to determined the value
i have send you a PM with links for the boardview
 ! igils писал(а):
Forum Rules
10 . To download the schemes and any other files which are already in the forum is forbidden.
12. To attach schemes to the messages is forbidden. For this purpose there is the appropriate theme in each subsection of the specific producer.
СообщениеДобавлено: 15 янв 2018, 00:44
I think you should have made a comparison of the two motherboards before posting.. :-) because they are in no way similar. LA-6841P is a Penryn processor and LA-6842P is Arrandale. LA-6842P boardview doesn't exist, so its just a matter of someone who has the motherboard reading the value of the resistor...
СообщениеДобавлено: 15 янв 2018, 04:21
oh, glad you pointed out, i didn't see it properly, sorry mate. You r right
i'll try to search for the real board
СообщениеДобавлено: 18 янв 2018, 12:01
Eventually I found out the value which was 20k and all voltages appeared but still no display (after flashing bios), unfortunately laptop was returned..
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite C660-238 (PWWHA LA-7202P) Ищу дамп BIOS Toshiba Satellite C660-238
в форуме Toshiba
keschka
19 июн 2016, 15:10
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. TOSHIBA Satellite P55W (TRCU MB REV: 2.2) Identification Of Component
в форуме Toshiba
abuholm
11 ноя 2017, 17:05
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba satellite c660-14J (LA-6842P) прыгает +CPU_CORE
в форуме Toshiba
dez-z
19
8655
20 май 2014, 22:18
orbit Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba Satellite C660-14J (LA-6842P) Греется дежурка
в форуме Toshiba
xusan
10
3774
13 сен 2014, 07:55
ars44 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba satellite C660-1J9 (la-6842p rev:1.0) Включается нет изображения
в форуме Toshiba
artivangel
11 ноя 2015, 17:20
jega Перейти к последнему сообщению
