Текущее время: 23 апр 2024, 10:13
andromedax
Заголовок сообщения: Re: Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs. Добавлено: 20 сен 2018, 20:36 |
Сообщения: 262 Откуда: Alicante, Spain
https://www.youtube.com/watch?v=6b4-hei ... 3&hl=en_USThis video from Sergey Vertyanov shows how to read the SMSC MEC1632, but seems that there is some problem. ( I can not understand really) I can see the datasheet for the SMSC MEC1632. ( I'm googled it but have no luck) Can someone share this datasheet? Can someone explain the problem to read the SMSC MEC1632 shown in this video? Regards
andromedax
Заголовок сообщения: Re: Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs. Добавлено: 21 сен 2018, 01:28 |
Vertyanov_SS писал(а): andromedax in MEC1632 JTAG locked. No DUMP, no solution ... Then solution is change MEC1632 for a new one. I wonder if the new chip is already programmed for this motherboard and if it is possible to upgrade its firmware via windows bios update. (and corrupted if something goes wrong) If someone can share more information it would be great. Regards.
andromedax
Заголовок сообщения: Re: Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs. Добавлено: 21 сен 2018, 12:59 |
Vertyanov_SS писал(а): andromedax If everything was so simple .... )) Yea, you are right, manufactures don't make "things" easy for technicians. What is worse, doesn't seem this are going to be better. Thanks for your help.
