Текущее время: 24 апр 2024, 18:01
chulat
Заголовок сообщения: Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flas Добавлено: 23 янв 2013, 15:56 |
Сообщения: 956 Откуда: Дербент
sebuncle
Заголовок сообщения: Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flas Добавлено: 24 янв 2013, 18:02 |
Зарегистрирован: 01 янв 2012, 19:29 Наличности на руках: 179.04
Сообщения: 81 Откуда: france
Hi can you tell me whick pin of PM6686 i have to check? Which voltage i have to find ? Best regards
_________________ Jovy RE7500
sebuncle
Заголовок сообщения: Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flas Добавлено: 25 янв 2013, 19:08 |
RsM писал(а): 1 - 2V 4 - 3,3 (logical "1") 5 - 3,3V 6 - 19V 7 - 5V 19 - 5V 27- 5V 25 - 3,3V
After down on-button must be
13 - 3,3V (logical "1") 14 - 3,3V 16 - 5V Hi , i have check voltage 1- 2v 4- 5.90v 5- 3.3v 6- 19v 7- 5v 19- 5v 27- 0v25- 0vafter power on 13- 3.3v 14- 4.6v 16- 5v pin 25 and 27 have no voltage what i have to check ? Best regards Posted after 1 hour 8 minutes 25 seconds:Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flashingi have check again and... i create a quicky short circuit now there's no voltage on pin 1,4,5,7,19 but ther's 19v on pin 6
sebuncle
Заголовок сообщения: Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flas Добавлено: 25 янв 2013, 20:33 |
pin 1,4,5,7,19 are output and pin 6 is an input it's right ? Posted after 56 minutes 25 seconds:RsM писал(а): Now you need new IC I have one in stock ,i have change it , the motherboard start with the same problem. What i have to check for pin 25 and 27 ? Best regards
sebuncle
Заголовок сообщения: Re: Sony vaio VPCS13C5E / MBX 216 /doesn't start , leds flas Добавлено: 26 янв 2013, 22:27 |
Hi, I'll buy a programmer and i'll try to flash bios after i"ll tell you Best regards
