VPCF129 caméra doesn't work https://vlab.su/viewtopic.php?f=55&t=13048 |
sebuncle [ 29 апр 2013, 22:14 ] | |
Заголовок сообщения: | VPCF129 caméra doesn't work |
Hi , laptop is a VPCF129 motherboard is a MBX215 , M930. The camera and the microphone does not work. I controlled the voltage on L1 and pin 1 of CN1 there is 0v. On U47 there's 3.3V on pin 1 and 0V on pin 5. I replaced U47, C7, C8 and C9 nothing changes. can you tell me where I need to check? Best regards http://imageshack.us/f/824/cameray.jpg |
sebuncle [ 02 май 2013, 11:10 ] | |
Заголовок сообщения: | Re: VPCF129 caméra doesn't work[solved] [РЕШЕНО] |
Hi , problem is solved . I have find another camera for test , I have replaced and it works. it was just the camera was defective now there is 3.3v on pin 5. best regards |
