Текущее время: 26 апр 2024, 19:53
 Заголовок сообщения: sony vaio sve15 (mbx-269) powers on then off
СообщениеДобавлено: 01 окт 2013, 04:10
hi all,
I have a vaio laptop that turns off in 1 or 2 seconds. I already took it apart and the voltage of all rails seems ok. the cpu is also in fine condition, there is no discrete gpu in this model.
I removed the 64mb bios chip from the board and connected it to a serial flash programmer, toked the bios update file from sony website extracted it and programmed the content of the rom file to the chip. after soldering the laptop refuse to turn on.
I think there is something special with this vaio board, the content of the update bios file is very different of the backup I made for the chip! encrypted? maybe but not sure. and where is the EC rom?
I think a bios dump from a working machine will answer my questions. if someone can share this file that would be nice.
some info:
vaio sve15 serie
motherboard mbx-269
original bios version R0160D6
thank you
 Заголовок сообщения: Re: sony vaio sve15 (mbx-269) powers on then off
СообщениеДобавлено: 01 окт 2013, 09:43
On Sony only update (part). It is not correct to program it in FLASH. Program your dump back. (Also upload it here)
Reconnect RTC battery. See all power rail.
-приворот winDOвSa
-розыгрыш автоБАНа
 Заголовок сообщения: Re: sony vaio sve15 (mbx-269) powers on then off  [РЕШЕНО]
СообщениеДобавлено: 03 окт 2013, 01:52
thanks for your reaction. finally the laptop worked and as I suspected the problem came from bios.
I get the working bios file from this page http://www.elvikom.pl/forum/viewtopic.php?p=104475
programmed the content to the flash chip and voila.
thanks again
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. W541 (48.4L014.021) Draws 1.8a then powers off
scobay
17 июн 2019, 22:11
scobay Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony SVE15 HK5 (SCHEMATICS SONYMBX-266-SVE15-HK5-MB-PVT-0202A) во Вьетнаме и хотите их опыт обучения в вашу ст
в форуме Sony
vhn1998
15 дек 2015, 23:37
FearCult Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. SVE15 (MBX-269) Bios Changes Not save
в форуме Sony
R EZ A
15 июл 2020, 11:52
Azazehl Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony SVE151 (Mbx 269) Disable Vga Mbx 269
в форуме Sony
Ngoalong
26 мар 2017, 10:10
Ngoalong Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. L770-14c (BS_R/TK_R rev:2.1) Powers off after 1 second
в форуме Toshiba
scobay
06 июл 2015, 15:57
s0ulbl4d3 Перейти к последнему сообщению
