sony fz340 (mbx-165) post code 87 https://vlab.su/viewtopic.php?f=55&t=16142 |
P.zonouz [ 09 окт 2013, 16:34 ] | |
Заголовок сообщения: | sony fz340 (mbx-165) post code 87 |
I soldered debugger to LPC port. I have no display. Debugger stops on post code 87. "Configure motherboard configurable devices (optional)" . I cannot recognize where to dig? |
torin [ 09 окт 2013, 16:38 ] | |
Заголовок сообщения: | Re: sony fz340 (mbx-165) post code 87 |
do not trust to the codes... They are not actual anymore... Try to remove the memory and check the if the code is the same or not... Generally this moodel has problem with video... I think you should dig there... Good luck! |
P.zonouz [ 09 окт 2013, 17:00 ] | |
torin писал(а): do not trust to the codes... They are not actual anymore... Try to remove the memory and check the if the code is the same or not... Generally this moodel has problem with video... I think you should dig there... Good luck! after remove rams code not changed. |
Sanya19 [ 12 окт 2013, 23:26 ] | |
On this board usual LPC debug card will never show codes after 87. Post 87 will be the last one you see, though actually there are much more codes after (you can see it with your oscilloscope). torin is right absolutely, typical failure on this board is GPU from nVidia. Start your "digging" from it. |
